[SOLVED] How to change QLC+ language ?
us272
Real Name: Jay Smith
I installed the QLC+ software on a french windows 7. Unfortunatly the program installed itself in french but would like to have it run in english (easier for me). Is there a way to manually change the language to have it run in english ?
Thanks a lot !
us272 wrote:I installed the QLC+ software on a french windows 7. Unfortunatly the program installed itself in french but would like to have it run in english (easier for me). Is there a way to manually change the language to have it run in english ?
Thanks a lot !
Try starting QLC+ from the command line with the -l option:
-l or --locale <locale> Force a locale for translation
qlcplus -l en
BTW I'm running linux and not completely sure this works with the windows cmd as well.
us272
Works fine now... Thanks a lot !!!
crispy71
Real Name: Christian
didn't work for me. I'm on MacOS and did as described in the manual (changing directory as described, then typed "qlcplus -l en") but the system returns "zsh: command not found: qlcplus"
kproth
Real Name: Kevin Roth
crispy71 wrote: Sun Dec 31, 2023 1:45 pm didn't work for me. I'm on MacOS and did as described in the manual (changing directory as described, then typed "qlcplus -l en") but the system returns "zsh: command not found: qlcplus"
Assuming you were in the correct directory, you likely have to put "./" in front of the command. I.e.: "./qlcplus -l en"
