Hi There,
Have been experimenting with QLC+ and loving it - so thanks for your work!
I have an eDMX2 MAX device (chose the DMX King latest/greatest, hoping I don't regret it) and I'm having difficulty getting it working with QLC+ as an artnet device. I have it working with a number of other apps (Lightjams, Luminair & Photon 2 on iOS, Touchdesigner) - but for the life of me I can't seem to get it recognized for QLC+, though I can if I connect it directly as USB.
I saw this forum post which made me suspect you have to have some form of manual updating: viewtopic.php?t=16562
And subsequently I tried the beta versions of both 4 and 5 available there (much slicker UI in 5 I must say! ).
Is there something device specific that I should be aware of? It's not on the supported list so I certainly couldn't fault you if it's not supported, but I had perhaps foolishly assumed you would be able to support the more recent devices as they come out from a primary vendor. Is it just a matter of time before it makes it into a build, or perhaps I'm missing something?
Happy to provide any logs/debugging. I'm a 20+ yr developer working on a wide variety of hardware devices, so no hesitation there, but certainly could have missed something obvious after a couple evenings of debugging.
Thanks again for the product and support!
eDMX2 MAX Support?
Hi, MAX support is integrated but not released yet.
You need to use TEST versions until the next official release.
viewtopic.php?t=3135
Do you have firmware 4.5+ as stated here?
https://www.qlcplus.org/discover/compatibility
I have uploaded an updated version for Windows.
Please try again with that one. Thanks
