qlc + 5 does not start
i see an empty white window. It works on 2 laptops.
- Real Name: Arjan van Heusden
Hi All,
I was staring at the white window for a while and tried the following, with success.. Maybe it helps some of you:
right-click 'qlcplus-qml.exe' in windows explorer -> 'run with integrated grapical processor' -> 'integrated graphics'
Per default it runs with the 'Powerfull NVIDIA processor' , which produces the tranquilising white window.
Just started with QLC+, really like it so far!
Best Regards,
Arjan
Best Regards,
Arjan
- Real Name: Kyle Sims
I have a intel motherboard i5 with a dual dvi port intel hd2200 videocard on the motherboard.
My issue is QLC+5 tries to open this I get a not responding message then it closes, this is a new build pc.
Is there a certain .net or c++ or something needed in order for qlc+5 to open? Note 4.12 opens just fine
So reading everyone else’s comments the issue is the onboard gpu? Would the issue be fixed if I added an pci slot gpu? If so what is a future proof gpu that will work with QLC+5 that is budget friendly?
I have been doing some research on google and I read about mesa3d and it allows people with intel graphics cards to run qt 3D based software. Anyone with more in depth pc knowledge can verify that?
on my build of the current git (1dd900900) i also only get a blank window.
The AppImage of the Beta1 works
I am on Debian/sid with Gnome 43.1
Edit:
I tried again on my Laptop (Manjaro xfce 4.18) and it works.
Edit:
Github: 8-Lambda-8
