Option for flash function to include fade in and fade out times
wolskey
Real Name: Sebastian Wolski
As mentioned above. It would create ability to bind scene as flash to a button and make it non binary (for example if we want to recreate old lamps warming time ~70ms using led lamps, and not to have binary effect)
I understand your use case, but as stated before, a flash will stay a flash. No fade times are possible.
wolskey
soo maybe buttons that are on only while pressed? :D
That is a flash button - and no - no fade times possible
unless you go to the dark side of QLC+ with loopback magic
