GUI cannot resize smaller than fixed value
meleneemil
Real Name: Emil Koul
Running QLC+ 4.12.4 on Linux Mint 21 on Thinkpad X1 carbon
I use two external screens side to side in portrait mode, but also tried it with proper landscape orientation.
The GUI does not respond to the Win+arrow commands to snap to corners, and its width cannot go below a certain value, 1296 (according to wmctl) which seems arbitrary.
My screens' resolution is 1200x1920 (x2).
Occasionally, it will respond, and be resizable to less than that.
I did check the other topic about GUI size, so it might be some other QT environmental flag, which I don't know about..
EDIT: trying again this morning...every time I open it it does something different (oscillating between good and bad state, i.e. being able to properly resize, and not)
thanks for any tips
Yestalgia
Thanks for reporting this.
I'm running 4.12.7 and the win+arrow keys work for me. Main monitor is 4k and secondary is 1680*1050.
Try updating to this version, otherwise a different display might do the trick.
Cheers,
Lachie
