I have been running a very old version of QLC+ for some time, and have been putting off upgrading because reasons.
I tried to open the .qxw file in the latest version and get the prompt to go to https://www.qlcplus.org/sequence_migration.php to convert the project.
However, when I try that, the migration tool seems to work and I see this...
719 Functions found.
3 Sequences found.
327 Sequence steps converted.
2 Scenes marked as hidden.
The converted zipped file can be downloaded here
But when I click on the download link (http://www.qlcplus.org/download_zip.php ... 2-15:42:11) nothing happens.
If I right click and do 'Save link as', I get a 0KB file that can't be opened.
Is the problem with my project, or the tool?
Project file attached
Sequence Migration tool not working
Thanks for reporting.
There is indeed an issue with the online tool.
I'll have a look and fix it ASAP.
In the meantime, here's you project migrated
- QLCTest_migrated.qxw
- (691.87 KiB) Downloaded 40 times
- Real Name: Dave Crewe
That's great, thanks Massimo!
Fixed
