Hi, I've installed the official image, but I want more controls on the pi, especially control qlc with VNC, the problem is that at boot the raspberry start qlc automatically as the root user and this window of qlc can only be view via the Hdmi and not in VNC.
The problem is that I can start a window of qlc via VNC but I end up with 2 qlc sessions (one whit root and one with pi)
It cause problem with uart control because information of 2 qlc adds up.
If I kill the root session it's work fine
I juste want to find how to disable this auto start
QLC auto start at boot
sudo systemctl disable qlcplus
- Real Name: Eliot Weinbrenner
Thanks, the exact command that work for me is this
sudo /lib/systemd/systemd-sysv-install disable qlcplus
