The same bug as in: http://www.qlcplus.org/forum/viewtopic.php?t=11351 is in 4.12.4.
> Copy sequence with multiple fixtures;
> Delete all but one fixture in the copy;
> play the show or restart qlc+ after saving;
> old fixtures persist in copied sequence.
Added show file and affected sequences fixture.
Sequence names: Led Par Random Color [folder] >Led Par # Random Color
Windows 10 64bit
Thanks for fixing in advance.
Copying sequences links copies to originals
- Light4Me-Penta-Par-8x12W-RGWA.qxf
- (3.08 KiB) Downloaded 67 times
- Show-2022.02.02 #2.qxw
- (241.61 KiB) Downloaded 68 times
1) you are not using the latest version... (there are test versions available)
Comparing the show may give @massimo a hint ->
Original With the copy and deletion of all but one fixture.
