Great, thanks.
Then there is something corrupted in the Appveyor environment
Another unwanted thing to spend time on...
[EDIT 2021-08-27] the issue seems to be fixed upstream now (4.12.5.29 works)
QLC+ TEST versions
- lorenzoandreani
- Real Name: Lorenzo Andreani
On Windows 10 - 10.0.19044, i have the same error using this versions:
QLC+_4.12.5.62.exe
QLC+_4.12.5.79.exe
QLC+_4.12.5.83.exe
the latest version that start is:
QLC+_4.12.5.29.exe
- Real Name: Mark Z
I am also seeing this behaviorlorenzoandreani wrote: ↑Thu Dec 02, 2021 1:30 amerror.png
QLC+_4.12.5.62.exe
QLC+_4.12.5.79.exe
QLC+_4.12.5.83.exe
QLC+_4.12.5.29.exe
I confirm this issue and unfortunately I haven't found a solution yet.
As a workaroud, you can copy all the DLL files starting with 'lib' (lib*.dll) from the official 4.12.4 package and the TEST versions will work.
- lorenzoandreani
Ok, it worksmcallegari wrote: ↑Fri Dec 03, 2021 6:06 pm As a workaroud, you can copy all the DLL files starting with 'lib' (lib*.dll) from the official 4.12.4 package and the TEST versions will work.
Latest Windows test version should be OK now
- edogawa
- Real Name: Edgar Aichinger
I wanted to let you know that I've just enabled Ubuntu 22.04 builds in our Open Build Service area.
No problems occurred, the builds just succeeded, but haven't been propagated to the download page yet, I expect that to happen within the next few hours.
It appears that the most recent Windows Test version (QLC+_4.12.8-20231110) does not load custom stylesheets. The other older version I have (QLC+_4.12.8.36) the sylesheet is loaded correctly.
viewtopic.php?t=16688BlandSauce wrote: ↑Fri Dec 15, 2023 8:11 am It appears that the most recent Windows Test version (QLC+_4.12.8-20231110) does not load custom stylesheets. The other older version I have (QLC+_4.12.8.36) the sylesheet is loaded correctly.
