Hi I'm still having trouble seeing new fixtures.
I am a Mac user and new to the programme.
I have copied a new fixture into the correct place so it should show in the library: 'show packed contents/Resources/Fixtures etc. But when I try and see it in the library when adding a new fixture within the programme it is not there. I even tried just adding a new folder and naming it to see if the programme was recognising changes in these folders but again I can't see any changes when trying to add a new fixture in the QLC programme.
Is there a solution or any way around this? Way to physically import the profile in a new project?
Still Can't see fixture even after file add to app
That's not where you place new fixtures
See #4 here: https://www.qlcplus.org/docs/html_en_EN ... swers.html
- Real Name: Mr Mike
These are the paths on a Mac:
Sounds like you need to drop the fixture definition in $HOME/Library/Application Support/QLC+/Fixtures.
/Fixtures
/InputProfiles
/MidiTemplates
/ModifiersTemplates
/RGBScripts
