widget: audio pulses
Hello, I would like to point out that;
1) during the execution of a song / audio, by activating the widget in audio pulses with the green check in the upper left active, the yellow bars go up and down according to the musical rhythm, but deactivating the widget with its green check when off, the bars freeze but do not reset, and the relative associations to the various functions do not deactivate.
2) I also add, by inserting two or more audio pulse widgets in the virtual console and activating them with the relative green check and audio in play, adjusting the input sensitivity of only one of them, this action affects the sensitivity of the other widgets (yellow bars of the others) even though the sliders apparently remain immobile.
3) is it possible to also associate the volume slider of the audio pulses widget to an external input, such as a midi controller, in order to adjust its sensitivity without necessarily using the mouse.
Thank you very much
widget audio pulses
- Real Name: Michele Carobene
