Slider in Submaster mode does not work with a Cue List.
ryhel
Hi guys,
I was trying to control intensity of a Cue List using a Submaster Slider.
I found that Submaster would only work for the very first Cue. Once you switch to next Cue - it would not work anymore.
Please, find a test solution, steps to reproduce and couple screenshots in this ticket.
Test solution includes:
1. 3 Generic RGB fixtures
2. Sequence (made using a "one by one" RBG Matrix )
3. Cue list that targets the Sequence
4. Slider in Submaster mode that should control the Cue list
Steps to reproduce:
1. Open solution submaster_test.qxw
2. Switch to operate mode
3. Open Fixture Monitor (to see what happens)
4. Start the Cue list (Cue 1)
5. Move the Submaster Slider up and down and make sure it controls intensity on fixtures
6. Switch to Cue 2 (hit Next in Cue list)
7. Move the Submaster Slider up and down again
Expected: Intensity should change in responce to Slider motion
Observed: Intensity does not change
QLC+ v. 4.12.2
Works fine:
Does not work:
Regards
submaster_test.qxw
(5.18 KiB) Downloaded 71 times
ryhel
I did some research on this, so looks like the problem is related to
Function::m_overrideMap
member which is being cleared by a
Function::resetAttributes()
call from
Function::postRun()
When I Start the Cue list it will apply Submaster value like this:
and this works.
When I click Next Step in the Cue List it will first apply Submaster value a bit differently:
(which seems to work too)
but then it will reset the attributes like this:
which seems to discard the Submaster value and reverts the original intensity.
ryhel
Finally, seems like I found an easy way to fix that:
Although I'not familiar with the codebase so much, so this may or may not be a proper way.
Hi, that might actually be the right fix. Thanks for looking into it.
I need to find some time to test your workspace.
That part is so delicate so I need to think if it can cause regressions elsewhere.
I have tested the fix and it seems to do the job!
Gonna push it upstream
Thanks again
ryhel
Good news. Thank you Massimo!
