It happens EVERY TIME you hit the the tap button (well, nearly every time)
It does NOT happen when I change the timing with the dial or with the + or -
See attached project: when you start the queue, the rgb matrix is filled.
(nearly) every time you press the tap, the filling process is immediately stopped and
begins from start ...watch with dmx monitor.
Since I have linked the tap through artnet to VirtualDJ, the "restart" occures permanently...
Yoko
Tapping on the time widges restarts RGB script
- Fehler Tap.qxw
- (5.03 KiB) Downloaded 68 times
- Real Name: AxelOtl
Do you need to use a cue list? Just use an animation.
- Fehler Tap.qxw
- (4.91 KiB) Downloaded 58 times
