Hi everyone
I have a question to ask you ...
as you can see from the image, my buttons have a dot that turns green when the corresponding memory lights up. Qlc + runs on MacOs Sierra.
It 'possible that there is no dot, but turn on the green button profile as I happened in the past?
Thanks...
Button's dot question
I'm afraid you need to manually remove the attribute from the project XML file.
If you share it I can do that for you.
The same file opened on another macbook does not have the dots but everything is normal ...
I tried to re-install qlc + but the problem was not solved ...
I also attach the file
Thanks Massimo!
Thanks Massimo!
- Qlc+Ponty#02.qxw
- (167.29 KiB) Downloaded 66 times
Totally forgot about this.
What you're looking for is in the Virtual Console "global" properties. Click on the icon and go to the widgets tab. There you can find the buttons style.
At some point you changed it and, like me, forgot where it was.
