Chauvet EVE P-100 WW, EVE P-130 RGB & OLORdash Batten-Quad 6
davbay1
Real Name: David
Hi everyone, I was wondering if anyone could help me out with a couple lights I have. Not sure if this needs to be separate threads or not so for now I'll just keep them all in one. It would be amazing if someone could make the configs for the following 3 fixtures.
Chauvet EVE P-100 WW - https://www.chauvetdj.com/wp-content/up ... v2_ML6.pdf (DMX Values are located on page 4 of this quick start guide.)
Chauvet EVE P-130 RGB - https://www.chauvetdj.com/wp-content/up ... ML6_WO.pdf (DMX Values are located on page 4 of this quick start guide.)
Chauvet COLORdash Batten-Quad 6 -I'm not sure if I will need a new config for this light because I see that we technically have one called "Chauvet-COLORdash-Batten". However it doesn't specify which model so I'm noit sure if it will work. The earliest I will be able to test that config is probably Saturday. But just in case, here are the DMX values of that light. - https://www.chauvetprofessional.com/wp- ... ev1_WO.pdf (This entire pdf is dedicated to dmx values.)
Thank you in advance for all of your help :)
David
floEdelmann
Real Name: Flo Edelmann
I've added all three to the Open Fixture Library:
It would be nice if you could provide the exact DMX ranges and colors for the EVE P-130 RGB's Color Macros channel :)
Have a look at the Open Fixture Library! It's a project to collect fixture definitions in a unified format and make them downloadable for different lighting programs, including QLC+ 4 and QLC+ 5.
