Searching patch for Big Dipper LS 90. Pls help)))
Or maybe I can use other fixture patch?
Anyway, I thank you in advance.
Sincerely Yours, EEvashka
Big Dipper LS 90
- Fxedel
- Real Name: Felix Edelmann
I've found the manual online: https://www.google.com/url?q=https://3l ... uEYa3KWqak
You can either use the QLC+ fixture editor to create your own fixture or you can use the online fixture editor by the Open Fixture Library to make it automatically available for other lighting programs as well.
Use the manual to get the DMX information that you'll need when using the fixture editor
Have a look at the Open Fixture Library! It's a project to collect fixture definitions in a unified format and make them downloadable for different lighting programs, including QLC+.
- EEvashka
- Real Name: Ivan Baluev
Thx for your reply and your work!
I visited the resources that you offered me. I will keep the manual for future work. However, the second link does not include Big Dipper. Maybe an alternative patch might do this?
Thousands of apologies for the inconvenience and thousands of gratitude for the work you have done.
- EEvashka
http://rgho.st/8Nd2vVBrR
- Fxedel
There is no QLC+ fixture for the Big Dipper LS90. I just gave you the resources to create it on your own
Manual URL without google: https://3live.ru/upload/iblock/e0b/LS90.pdf
I've made a fixture definition.
I've found some gobo pictures but not all.
The manual isn't perfect, some of the descriptions aren't as well translated as perhaps they could be so I've tried to describe what I think they mean rather than what they've written.
Channels 8 and 10 both have entries for values 0-10 then 10-250, which can't be right as it should be 0-9, 10-250 or 0-10, 11-250. If someone could test and find out which is right that would be great.
- Big-Dipper-LS90.qxf
- (6.36 KiB) Downloaded 405 times
