Open DMX weird behaviour in Function Manager
giacomo
qlcplus 4.11.1 qt5 from linux automated builds, arch linux 64.
First time I've used an Enttec Open DMX:
in Function Manager, all the lights I was using to adjust a scene didn't go off after switching to another scene,
I ended up with everything on.
Restarted Qlcplus with the same result, then tried to enter in Play Mode and bring down the levels in the Virtual Console manually, then everything was working as expected.
Unfortunately I can't test it again today on a real stage and yesterday I had just half an hour to connect everything and make corrections, so I couldn't investigate it further.
