Artnet - Arduino - Delay output
almarques
Real Name: Alex Marques
Hello!
I assembled an Arduino-based artnet with 3 universes.
The first and second work well, but the third one has a very long delay, someone had a similar problem?
I did tests connecting in other software and also in other controllers and I have no problem in the third universe, only in QLC it has this delay.
The arduino system was built based on this:
http://www.deskontrol.net/blog/arduino- ... tnet-node/
Tks All!
Alex Marques
Elton Som e Eventos
www.eltonsom.com.br
And what if you only try the third one?
* still timing troubles -> Arduino bad
* no more troubles -> check networking capabilities??
Narrowing the problem will show you the source of the problem
almarques
how much testo with other programs or in other consoles via artnet I do not have this problem.
Always use the same connection scheme (same router and same cables)
It happens in universe 3 ... in 1 and 2 I have no delay.
I also used to test this software, which looks for artnet devices on the network
http://www.artisticlicence.com/index.ph ... uct_id=351
In it everything works correctly, I do all the tests in the 3 universes without any delay.
I have already tested on other PC and MAC computers and the problem is always the same ...
Tks!
Alex Marques
Elton Som e Eventos
www.eltonsom.com.br
Are you broadcasting or unicasting?
* these setting can be different between software products and QLC+ can be set to unicast or broadcast... (even sending the full scope [universe] or only the relevant info)
Saying it works with other products won't help solving your troubles with QLC+ - just saying ;-)
almarques
Hello, it's not a comparative issue, running the other programs is just a parameter for me to try with the help of the forum to solve the problem, I like the QLC and I continue to use it successfully with 2 universes.
I have already made this change, without success as well.
Alex Marques
Elton Som e Eventos
www.eltonsom.com.br
