No more audio devices in QLC+
Which image are you using ?
That's clearly not my image. Please provide all the information if you want help
- Real Name: Jiri Bednar
Again, you're not providing all the information needed:
1- where did you get that deb file ? That's not the name of the package I provide
2- which image are you using ? (Raspbian Wheezy, Jessie, Stretch, ??)
3- Which Qt version is installed in the image you're using ?
4-
4-
What does this even mean ? What is not working ? What did you see ?I got a link to download the current version, but this version will not run at all.
1. I downloaded from GIT source files and compile it (According to instructions from the web)
2. jessie 4.9.35-v7+
3.QT5
4.The QLC + version of the email will not display anything. I will run and nothing.
Thanks for your patience, I'm not a Linux expert.
3.QT5
Sorry but I can't give support to custom built versions. You say you're not a Linux expert but you built QLC+ from sources yourself...wow.
Qt5 is still too generic. There are like 20 versions out there.
My image has to work out of the box on a Raspberry Pi 3. If it doesn't then it means something went wrong when flashing it on the SD card. Are you sure you have properly followed the instructions ?
You should see at least the Pi boot splash screen (a colorful square on the TV) or the kernel boot messages.
I installed jessie 4.4.50-v7 + (downloaded from the official raspberry site), I installed qlc + 4.11 from the email (donation). But qlc + will not run at all. What is the installation procedure for the new system installation? What do you need to install? I'm sorry for my ignorance, but I have not found any instructions. Do I need to install qt5 again? What version of raspbian qlc + is running on?
Chapter 10 of the provided PDFWhat is the installation procedure for the new system installation?
Chapter 10 of the provided PDFWhat do you need to install?
Chapter 10 of the provided PDFI'm sorry for my ignorance, but I have not found any instructions.
Chapter 10 of the provided PDF. Yes.Do I need to install qt5 again?
Jessie. It's written here: http://www.qlcplus.org/raspberry.html, In chapter 2 of the provided PDF, and in the name of the PDF itself.What version of raspbian qlc + is running on?
Dude, your issue is that you refuse to read the instructions.
Therefore, my help ends here, cause this is a waste of my time.
