Dear friend's
I have create a multi page frame, and inside i have put 2 the frame exclusive in th first page and the slider in the 2 page, and i have this problem:
- when i launch the console and i use the first page i dont have a problem, but i chance in the second page the slider it's ok but when i return i the fist page the button it's no work .
Can you help me please ?
Multi page
Please attach your workspace file (.qxw) and any custom fixture definitions (.qxf).
- Real Name: Grigis Simone
In attached i send the worksspace and the fixture
Thanck you very much for the help
- Spettacolo Cinema Stella Alpina Selvino.qxw
- (52.92 KiB) Downloaded 35 times
- LED-PAR-RGBWA+UV-10CH.qxf
- (2.76 KiB) Downloaded 30 times
- Proel-Fog.qxf
- (854 Bytes) Downloaded 29 times
- Real Name: Lukas
Hey,
I tried you workspace and was not able to reproduce what I got from your description. I assume step by step it would require these things to do:
Please also state your QLC+ version.
[EDIT] As a side note I noticed a bug when opening your workspace with the latest source code, I already provided a PR which fixes this. Anyway, I don't think this is related to the issue described above.
- Try page 1 (works as expected)
- Go to page 2, try the slider (works as expected)
- Go to page 1, try it again (does not work as expected)
- Real Name: Lukas
