Cant get out on this on rpi3??
Re: Cant get out on this on rpi3??
Post by mcallegari » Wed May 10, 2017 5:15 pm
They must have changed something with the latest Raspbian updates. Please post:
- kernel version
uname -a
- the output of the command
cat /proc/cpuinfo
asm
Real Name: Allan Madsen
Post by asm » Wed May 10, 2017 6:04 pm
uname -a
Linux raspDMX 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux
cat /proc/cpuinfo
processor       : 0
model name      : ARMv7 Processor rev 4 (v7l)
BogoMIPS        : 38.40
Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 1
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 2
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 3
BogoMIPS        : 38.40
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
Hardware        : BCM2835
Revision        : a02082
Serial          : 00000000af6723d3
Here it is.
Post by mcallegari » Thu May 11, 2017 7:03 am
Thanks for the info.
Indeed kernel changed from 4.4 to 4.9 and they changed how cpuinfo is formatted too.
That's why QLC+ is not recognizing that it is running on a Raspberry Pi.
I think for now you need to stick to my image and eventually update all packages except for the Linux kernel.
This will be fixed with my next image.
asm
Post by asm » Thu May 11, 2017 7:50 am
Thanks, for your answer. :-)
How log to new update?
Is there a way to make a shutdown key, in the console?
And keep up the grate work you are doing :-) Love you program.
Just got a $0.86 usb soundcart to run on it to with mic in :-)
MyGreenhorn
Real Name: Mayk Peter
Post by MyGreenhorn » Fri Jun 16, 2017 5:08 pm
I have got pretty much the same problem, since I did "sudo apt-get dist-upgrade".
However QLC+ uses only 1/4 of the screen (upper left corner)
Even worse: I cannot get into a terminal session any more, as the button
to exit QL+ has disappeared.
How can I start a terminal session or prevent QLC from starting up?
Post by mcallegari » Fri Jun 16, 2017 5:28 pm
A new image version will be released soon, please be patient.
In the meantime don't do a package upgrade.
The image is consistent to work with the packages of the date it has been released on.
MyGreenhorn
Post by MyGreenhorn » Sat Jun 17, 2017 10:42 am
thanks for the quick answer.
Actually I found meanwhile that the "resize fullscreen" option does work,
also for the RDP session. The "--nowm" option doesn't work for me yet.
Looking forward to the next image! Thanks!
Post by mcallegari » Sun Jun 18, 2017 11:39 am
That's because it hasn't been released yet ! (you probably found it in a TEST version, right ?)
Anyway, that's the option that will restore QLC+ correct screen resizing in the next RPi image.
