QLC+ Web Interface With Mac OSX 10.75
Tracy
Post by Tracy » Mon Dec 26, 2016 4:44 pm
I've tried to get the QLC+ web interface activated a couple of times on my Mac using Terminal, but I'm getting "No Such File Or Directory" when I type in "QLC+.app\Contents\MacOS." The program is terrific... I'd like to run it via my tablet.
I renamed the file image "QLC+.DMG" (it previously had the version as part of the file name). Since my QLC+ program resides within my Applications folder, I've tried including the Applications directory within the command, still the same result. Assuming the image is "QLC+.dmg" residing within the Applications folder, can somebody please give me the exact terminal commands to get the web interface activated step by step? Thank you and happy holidays!
Re: QLC+ Web Interface With Mac OSX 10.75
Post by mcallegari » Tue Dec 27, 2016 10:47 am
"QLC+.app\Contents\MacOS" is a directory within the bundle.
You need also to invoke the actual QLC+ binary, like this:
QLC+.app\Contents\MacOS\qlcplus --web
Tracy
Post by Tracy » Thu Dec 29, 2016 10:26 am
Hi Massimo,
Thank you for your help.
You know, I just copied and pasted that into my terminal. This is what I get: (see attached screenshot).
I hate to be a pain.
Tracy
Post by janosvitok » Thu Dec 29, 2016 12:18 pm
most probably you need to use forward slashes ('/') instead of backslashes ('\').
Tracy
Post by Tracy » Thu Dec 29, 2016 9:15 pm
I did try using forward slashes and the "open" command. I could actually see the "Framework," MacOS, Plugins, Resources folders, but I couldn't get the program to open up and have the web server. Keeping at it.
mlohrey
Real Name: Mark Lohrey
Post by mlohrey » Fri Dec 30, 2016 4:38 am
Hi Tracy,
If you have installed QLC+ in your applications directory then use this terminal command:
/Applications/QLC+.app/Contents/MacOS/qlcplus -w
Otherwise, a neat way of specifying a file path in terminal is to drag and drop the location.
Right-click the QLC+ application and then choose 'show package contents' then navigate to >content > macOS and drag and drop the qlcplus application into new terminal shell. You can then add the -w.
You can now access the web interface at http://localhost:9999/ (localhost should work but it will depend on your hosts file. Sometimes they can get messed up. Use the ip of your mac otherwise.)
Cheers
Mark
Chris De Rock
Post by Chris De Rock » Tue Apr 25, 2017 7:55 am
Just seen this Thread and looking at the code... For Mac OS we can modify the Launcher, add an extra button "Launch with webaccess" and call "launchQLC(QApplication::arguments() << "--web"); ". i testet this and it works. Maybe we can add a Shortcut for windows user too
ralbrightii
Real Name: Russell Albright iI
Post by ralbrightii » Tue May 23, 2017 11:18 pm
Could you elaborate on this a bit. please
