Please help,I need fixtures Qtx light mhs-60,Qtx light Lux-ld30w,Jbsystems light Twin effect.
https://www.proaudiocentre.com/docs/150452.pdf
https://www.manualslib.com/manual/72741 ... Ld30w.html
https://www.manualslib.com/products/Jbs ... 05724.html
QTX
- Real Name: Nerijus Mongirdas
Adjust, please. Thanks
https://jb-systems.eu/plano-spot
https://www.proaudiocentre.com/docs/EQLED53-um0.pdf
Adjust please. Thanks
- QTX-LIGHT-LUX-LD-30.qxf
- (3.13 KiB) Downloaded 87 times
- QTX-LIGHT-MHS-60.qxf
- (93.91 KiB) Downloaded 113 times
- Real Name: Robert Box
Here's the QTX part adjusted. No idea why the pan/tilt channels had a channel range for EACH number.
- QTX-MHS-60.qxf
- (4.34 KiB) Downloaded 93 times
- floEdelmann
- Real Name: Flo Edelmann
For the JB Systems Twin Effect Laser, see my reply on your other thread.
As for the QTX LUX-LD30W, that is also available from the Open Fixture Library. You can view it here: open-fixture-library.org/qtx/lux-ld30w
Just click Download as QLC+ in the top right corner.
Have a look at the Open Fixture Library! It's a project to collect fixture definitions in a unified format and make them downloadable for different lighting programs, including QLC+ 4 and QLC+ 5.
Thank you very muchfloEdelmann wrote: ↑Tue Sep 19, 2017 1:11 pm For the JB Systems Twin Effect Laser, see my reply on your other thread.
As for the QTX LUX-LD30W, that is also available from the Open Fixture Library. You can view it here: open-fixture-library.herokuapp.com/qtx/lux-ld30w
