I have managed to get my hands on a Martin Mac 401 Dual Zoom.
I have been looking at creating a definition for it but can't work out what to do with the modes.
There are officially six modes and within those, three separate ways to split the main head into zones.
On top of that a second head can be attached to the back of the unit.
Here is a link to the manual http://www.martin.com/Martin.Download.a ... 1_EN_E.pdf
My feeling is that I will create a definition for my own use, with just the one RGB head attached, with six modes covering (calibrated RGB, un-calibrated RGB and HS) with 3 ways to split the head and (the same again but with effects).
What are other peoples ideas.
Fixture Definition Advice
- Real Name: Tim Cullingworth
Quick question, what do we do with Hue, saturation, value channels?
I have a feeling that QLC+ and the fixture editor does not support these as yet. If I am wrong please tell me as I could not find them in the channel descriptions.
Tim,
you are right. There's no support for H/S/V channels yet. If they were, most probably the channels would be marked as Intensity, with color = Hue/Saturation/Value.
Since they are not supported, marking the channels as Intensity with no color would mark them as dimmer channels, and I'm not sure whether is it desired (RGB matrixes will set them to full).
If you mark them as Effect or Color, they will be LTP.
This adds three TODOs:
- add H/S/V colors to QLC+ (including RGB matrix and color picker; QColor does the conversion)
- add "Other" color to avoid similar problems (e.g. with CTO channels) for which we want HTP behavior
- this is harder: split dimmers and primary colors to different group.
What are your thoughts about H/S/V regarding HTP/LTP? I'd guess that S and V are clearly HTP, and I'm not sure about H.
