Eurolite ERX4 DMX
jszabolcs2006
Real Name: Szabolcs Jászberényi
A simple 4 channel relay switcher, with 2 modes.
Users manual: http://www.produktinfo.conrad.com/daten ... _fr_es.pdf
Corrected the file, added heads so the 2D view shows the 4 channels now.
Eurolite-ERX4.qxf
(2.27 KiB) Downloaded 78 times
DIY open DMX (USB-DMX) box(es)
Novation Zero SL MKII
Ubuntu Linux 18.04 LTS
Thanks for sharing! Since this is a simple dimmer pack, there is no need to create an extra fixture. Simply use the Generic dimmer with 4 channels.
jszabolcs2006
I made this fixture, because it has 2 modes (1ch dmx controls all 4 output, or 4ch where each channel has its dmx channel), and it is a Switcher pack, not a dimmer. So the channel values make a channel on/off, instead of dimming.
Okay, I see now. But I'm still not sure if we should add this type of fixtures.
@massimo, what is your opinion?
jszabolcs2006
If you do not want to add this exact fixture, then maybe you could make a generic switcher, just like the generic dimmer. It would make sense, since they work all in the same way as I know. :)
