Fixture Editor - Add Lamp Type
lorenzoandreani
Real Name: Lorenzo Andreani
In fixture editor i do not see the lamp type "Msd Platinum 15r 300w"
You can add this lamp type?
QLC+ 4.10.4
I've thought it's a quick fix to add it, but it seems that the values are in two places, so besides adding this one value,
the code calls for a small cleanup as well...
I was wrong, it was simple.I've added "MSD Platinum 15 R 300W" to git version.
lorenzoandreani
Ok, good
Might also be useful to add an entry in the combobox indicated "Not defined" to use if do not know the type of lamp or is not on the list
lorenzoandreani
I thought it would be useful to have a report with the energy consumption values ​​of the fixtures used in a show so you can know the total current load of the stage
