Entering channel and capability data
boxy
Real Name: Robert Box
Having gone through a lot of new fixtures, there seems to be a lot of diversity in how people fill channel and mode info in:
This is MY personal preference on how fixtures should be done:
1. Treat each channel name as a heading, and so capitalise the major words.
eg.: FX Wheel (Wheel 3): Static Gobos and Animation Effect Selection, Rotation, Animation Movement Type
2. I treat each capability as a sentence or sentences (multiple use functions seperated by a '/'), and only capitalise the first word of each sentence.
eg.: Black/Slow to fast/Less sensitive to highly sensitive
3. If the maker uses 'Fast to slow' I will use 'to'. if they use <-->, or -, or -->, or →, I do the same.
4. If the maker uses 'color' or 'colour', I do the same.
5. Where it is ambiguous what to put in the capability extract the info from the manual.
eg.: In one fixture, I called amber intensity 'Amber' (intensity is implied). The capability was 'Gradual adjustment, from 0-100%' (too much but ripped from the manual).
6. If there is a multi-function channel controlled by other channels, don't create several modes for it as this doesn't work. Split the capabilities where the the functions change for each mode:
eg.:
Channel name - Letter/Number/Speed Adjustment (Increasing Speed 0..255)
Capabilities -
0-9: Letter 'A'/Number '0'
10-19: Letter 'B'/Number '0'
20-27: Letter 'C'/Number '0'
28-29: Letter 'D'/Number '1'
The letter selector changes at 10, 20, 30... The first number selector changes at 28. So, Number '0' appears 3 times. You could argue above that 'Increasing Speed 0..255' should be on each line. It's not because it covers the whole range of values so only needs mentioning in the title.
7. If the manual says CW or CCW etc, so do I. However, if there are blatant typos or bad English, I will correct it.
8. Add a master fader if there is one to all the heads in each mode. This is mentioned in the docs but seldom gets done.
9. I'm not sure on gobos. If they are not removable then use the icon. If they are then the fixture will be out of date when they are changed.
That's it! Now feel to free to add your ideas...
I've turned this into a sticky post, in case blind users miss the sharing guidelines :)
Ovis
Real Name: Ovidijus
What should I do in this situation?
In fixture editor I can't add from 48 to 48. I need to do 48 to 49. So that's not correct, nex function will start from 50, but manual says it needs to be 49 :?:
ENTTEC PRO Mk2
AKAI APCmini
plugz
Real Name: David
Ovis wrote: What should I do in this situation?
This issue has been fixed for the future 4.10.2 version. If you cannot build QLC+ from sources, you may try a TEST version.
Ovis
Real Name: Ovidijus
How to set Colors for fixtures, that 2D monitor would be able to show them? In my case, some of my fixtures show colors in 2D monitor correct, some fixtures only white. Tryed color wheels, C/M/Y but it's only white.
Latest QLC+ on OS X.
In this fixture I only see White color.
PR-Lighting-XR-230-Spot.qxf
(19.98 KiB) Downloaded 474 times
ENTTEC PRO Mk2
AKAI APCmini
IIRC, 2D view should recognize:
- RGB channels (all 3 must be present) (Group = Intensity, Colour=Red/Green/Blue), controls color
- CMY channels (all 3 must be present) (Group = Intensity, Colour=Cyan/Magenta/Yellow), controls color
- Color Wheels (Group = Colour) - controls color
- Dimmer Channels (Group = Intensity, Colour=NoColor), controls intensity (0%-100%)
- Shutter Channels (Group = Shutter), controls intensity (on/off/blinking)
if no color information is detected, then white is used.
Can you show an example of a non-working definition?
Ovis
Real Name: Ovidijus
Here is VC on which I have problem with PR XR Spot colors in 2D. Few colors is from color whell, some with CMY. There is OPEN button for shutter.
XRproblem.qxw
(266.62 KiB) Downloaded 363 times
ENTTEC PRO Mk2
AKAI APCmini
Remove from CMY Macro and color wheel value WHITE, or at least remove the RGB value from them.
Ovis
Real Name: Ovidijus
Ok, thank You. :)
ENTTEC PRO Mk2
AKAI APCmini
andres robles
Real Name: Andres Robles
for that mistake, what I do is, add value, (0-37) and pressed ok in the two dialogues, then continue editing ... (038- 126) ... ok ... ok... It is slower but works for me...
SaLT
Real Name: Andreas
Hallo @all,
I'm new to the QLC+ and come from myDMX and LumiDesk. So first I have to transfer all my SSL2 fixture definitions into the QLC+ format.
Unfortunatelly it's a lot of work, because many of my fixtures are not (or not completely) represented in the database.
Theferfore my first question is, if there is a tool available for transforming SSL2 fixture representations (mininum roughly the channels, DXM ranges, textual descriptions) into the QXF format?
It would spend a lot of time, because some of my moving video beamers have up to 54 channels with a lot of channels which have possibly 50 to 200 DXM ranges per each. Typing it manually again (I did it already for SSL2) would be a nightmare.
Some of my fixtures have a lot of channels which are all of type "Effect". Is it possible to give effect channels individual icons (instead of the star) for an easier distingushing the one from the others, e.g., in the simple desk view?
Thanks a lot for your quick answer.
Regards
Andreas
It's not possible to set custom icon for effects channel.
There is no import from SSL2 as far as I know. Quick search on the internet tells me that it's an undocumented binary format, so unless there is editor that can export it to something readable,
there's little hope for converter.
There is import from Avolites D4 format. You may find a definition for your fixtures on the Avolites site.
Can you tell us what model/make are your fixtures?
mitscherdinger
2 questions on this:
boxy wrote: Wed Nov 18, 2015 12:20 pm 6. If there is a multi-function channel controlled by other channels, don't create several modes for it as this doesn't work. Split the capabilities where the the functions change for each mode:
eg.:
Capabilities -
Which category of capability should I use, then? I mean, QLC+ seems to handle different categories differently, doesn't it?
Example: I'm editing a fixture for the Eurolite LED KLS-2500, and somehow in one mode the manufacturer decided to use dimmer AND speed adjustment in one channel, depending on the value of another channel. I guess, I can't use something different then "intensity" here, although I don't know how "speed" is handled. (Using "effect" would break fading, wouldn't it?)
boxy wrote: Wed Nov 18, 2015 12:20 pm 8. Add a master fader if there is one to all the heads in each mode. This is mentioned in the docs but seldom gets done.
Just to understand it right: I have a LED bar with 4 spots and this device does have a 13-channel-mode with RGB on each spot (3+3+3+3 channels) and a dimmer channel on the 13th, then "heads" should be used like this:
Head 1 (1,2,3,13)
Head 2 (4,5,6,13)
Head 3 (7,8,9,13)
Head 4 (10,11,12,13)
right?
mitscherdinger
Anyone?
Just one of those questions?
Interdependent channels are not supported right now.
A rework on fixture definitions is ongoing on a GIT branch, which will tackle this issue among others.
Will surely post some news when I have some.
Heads question: correct.
mitscherdinger
Great stuff, again, Massimo!
And thanks for answering the heads question - this means, I have to overwork the Eurolite LED KLS-2500 and the IMG Stage Line PARL4-SET. Coming soon!
Katekla
I'm trying to build this Chroma Q fixture, got the first 1-7 channels in, and now stumped on the channels 8 and 9. Does anyone have any ideas?
Also this ECL Profile, the last few channels are giving me trouble.
If anyone has previously built these, or has done channels with the similar parameters, advice would be really welcome.
Kate
