qlcplus 4.10.3a on debian jessie based system
sebo505
I am using qlcplus on a debian jessie based system. I am using a DMX USB NanoDMX Interface (DMX4ALL). This interface gets detected properly. qlcplus says that the interface is ready to use ant that the libFTDI driver is used.
So I added my fixture (ignition LED PAR64 floor 20x3 W PWM RGB). But the fixture does not respond at all.
Any suggestions?
sschaeffner
Real Name: Simon Schäffner
1. check your cables,
2. check your dmx address set on the fixture,
3. try with simple desk
4. try with another fixture
If none of these steps solve your problem, there's most likely a problem with your dmx interface. If you have any windows based pc around, maybe try with that.
Simon
sebo505
Cables are fine
dmx address is fine
fixture is fine
does not work with simple desk either
dmx interface is brandnew
haven't tried a windows machine yet, but must be something else.
Any ideas ?
sebo505
i also tried to add the user to the group dialout. this did not change anything.
though I figured out that everything is working fine if I start qlcplus as root.
So, what do I have to change for that it is also working as normal user?
Looks like the udev rules are not applied.
Or probably your user must be added to the 'dialout' group.
Check groups until
echo "foo" > /dev/ttyUSB0
works
