The following command works from the command line (using Linux):
audtool set-volume $(('audtool get-volume' - 5))
I cannot get that to script. I have tried many variants of the following
systemcommand:audtool arg1:"set-volume" arg2:"$(('audtool get-volume' - 5))"
Is there some syntax trick to getting the exact line passed to the OS?
Scripting systemcommand argument passed badly
Maybe you need to call bash to do the parameter expansion.
systemcommand:bash arg1: "audtool" arg2:"set-volume" arg3:"$(('audtool get-volume' - 5))"
- Real Name: Chris Laurie
Thank you for the response Jano!
Unfortunately that did not work.
- sbenejam
This is a command that calls a python test script that I use: systemcommand:python-script.py arg:dspdfviewer arg:P
Maybe it could help.
- Real Name: David
Try this one:
systemcommand:bash arg1:"-c" arg2:"audtool set-volume $(($(audtool get-volume) - 5))"
I have written an example in the documentation, so where did you guys read arg1, arg2, etc ?
http://www.qlcplus.org/docs/scripteditor.html
most likely this is what you want
By the way, this looks more like a usage question rather than a issue report...
systemcommand:/usr/bin/vlc arg:-f arg:/home/user/video.mp4 // plays my video with VLC in fullscreen
systemcommand:audtool arg:set-volume arg:"$(('audtool get-volume' - 5))"
- Real Name: David
You're right, arg1 arg2 etc is useless.mcallegari wrote:I have written an example in the documentation, so where did you guys read arg1, arg2, etc ?
But it works. You can also replace "arg" with "hi" or "hello", it will work too. Should a github issue be opened for this ?
This does not work, becauseCode: Select all
$((`audtool get-volume`))
audtool get-volume
Maybe.By the way, this looks more like a usage question rather than a issue report...
Please try this one:
systemcommand:bash arg:-c arg:"audtool set-volume $(($(audtool get-volume) - 5))"
Ugh...yes pleaseBut it works. You can also replace "arg" with "hi" or "hello", it will work too. Should a github issue be opened for this ?
Then have a look at #843 please
Right. I'm wondering if the QProcess class can actually work like a proper shell. I'll check the docs when I have some timeThis does not work, becauseis something that has to be interpreted by bash. QLC+ does not run processes through bash commands. Also, I think the simple quote aroundCode: Select all
- Real Name: David
No it can't. It's not a shell command interpreter. It simply runs a process.mcallegari wrote: Right. I'm wondering if the QProcess class can actually work like a proper shell. I'll check the docs when I have some time
And I think it's fine like this. Users can still use "bash -c" to run shell commands. Or even write the script in an external .sh file.
Actually, you can pass the system environment to it:plugz wrote:No it can't. It's not a shell command interpreter. It simply runs a process.mcallegari wrote: Right. I'm wondering if the QProcess class can actually work like a proper shell. I'll check the docs when I have some time
http://doc.qt.io/qt-5/qprocess.html#set ... nvironment
In any case I agree regarding a shell script.
I would do something like
setVolume.sh 5
setVolume.sh -5
That is what I did in the end I created a shell file. I could not get the bash -c to work. This solution probably won't work in Windows.
One thing that would work for this use case is if the scripting allowed for the interim storage of the result of a systemcommand call - some like this
%v = systemcommand:audtool arg1:get-volume
systemcommand:audtool arg1:set-volume arg2:%v - 1
Not sure about how the syntax will work but that would give us the start of the capability to read and set dmx channel values via these variables.
- Real Name: JoelM
systemcommand:/bin/sh arg:/home/pi/PP-QLC-Lights/ShowVoxON.sh // copies show file with vocals to correct location
This is what in a few different versions I use to change audio files used in a show... works great. Attach it to a button and OSC command.
