Problem with Victory II 250
The issues found when using the Fixture Manager panel
Sbs
Real Name: Stefano
Hello everyone, I have a problem with the Victory II 250, with qlc not respond to any commands, while the 12/24 console of Eurolite all ok ... Can anyone help me please, is urgent .... Thanks
plugz
Real Name: David
Sbs wrote:qlc not respond to any commands
So you're in front in your computer and you yell "DO SOMETHING" and qlc+ does not answer to you ?
Sbs
Real Name: Stefano
I led and the par 4 mini wash and they work perfectly, while victory will not respond to any commands !!!!! :(
I think what David meant is "what the hell are these "commands" you're talking about ??"
Sbs
Real Name: Stefano
Hello Massimo, practically meant that all moving heads and par LEDs work with qlc while the Victory II 250 do not move, do not light, do not work, as if he got the dmx signal ... that's all ...
plugz
Real Name: David
- What is your DMX interface ?
- What exactly have you tried ?
- Have you tried with only the victory II connected ?
- Have you tried with another cable ?
- Have you tried with a DMX terminator ?
- Are you SURE the address is configured correctly ? Have you tried with address 1 ?
- Have you tried with another DMX interface ?
Stefano, please try to be a little bit more cooperative as we cannot understand what you're doing if you don't provide the necessary details.
Keep on saying "it doesn't work" "it doesn't move" "it doesn't light", doesn't bring any contribution to this thread.
Please do this:
- set the Victory to DMX address 1
- connect it alone to the DMX cable (and no other fixtures)
- open QLC+ , go to simple desk and move manually some channels
Then please come back with the results.
[P.S.] Topic moved into the presumed category
Sbs
Real Name: Stefano
I've done everything you have suggested and nothing, the machine does nothing .... sorry if I am not clear but it is not easy to explain the problem.
plugz
Real Name: David
plugz wrote: - What is your DMX interface ?
Sbs
Real Name: Stefano
I have a generic Usb Dmx interface but with Protocol Enttec ... with other heads it works fine ...
Sbs wrote:I have a generic Usb Dmx interface but with Protocol Enttec ... with other heads it works fine ...
Please define "generic Usb Dmx interface"
If you're using one of those crappy chinese adapter bought on ebay for $10, then you might have your answer. Probably the Victory is more sensitive than your other heads to a precise DMX signal
