Mac OSX Segmentation fault: 11
The issues found when using the web interface
ianjamespiano
Real Name: Ian Ritter
Hi Everyone! Very new but excited about QLC+ thank u!!
Mac OSX 10.11.3
When connecting remotely through the Web API test page uploading my .qxw file when I tap the button in the browser window the QLC+ program quits and gets this error in terminal Segmentation fault: 11
Thanks For any help!!
IanTestWeb.qxw
(2.38 KiB) Downloaded 633 times
ianjamespiano
On iPhone 6 using goole chrome it crashes with the segmentation fault : 11
any ideas? thanks!
plugz
Real Name: David
Which qlc+ version ?
ianjamespiano
Hi QLC+ version 4.10.3a
plugz
Real Name: David
I can't reproduce the bug on linux.
- What is the exact procedure to make QLC+ crash ? (which options do you pass to QLC+, what buttons do you click on once QLC+ is started...)
- Does OSX give you informations other than "Segmentation fault" ? Like a backtrace or something ?
ianjamespiano
Hi again thanks for the replies!
On macbook it works fine with chrome but trying to use it on iOS iPhone the crash happens
I just have One Button Turning one light on and off (red color).
I attached what the crash log that opened up said. Thanks for the help!!
QLC+crash IOS RemotePDF.pdf
(100.71 KiB) Downloaded 536 times
plugz
Real Name: David
Thank you for the crash log, this helps a lot.
ianjamespiano wrote: On macbook it works fine with chrome but trying to use it on iOS iPhone the crash happens
I'm sorry but this is not sufficient. We need a lot more details.
As an example, that's what I did to test this bug:
- I start QLC+ with the -w option
- I load the workspace you uploaded here workspace
- I type localhost:9999 in the address bar of my browser to get to the web access page of QLC+
- I click on the Red Scene button on the web access page
- It works (the scene is started, there is no crash)
The order in which you did things may also be important.
Thank you.
ianjamespiano
Hi here are the steps.
1. load Qlc+ from terminal with the -w web protocol. This opens up QlC in a New Workspace
2. Open chrome on iPhone and go to the Qlc Web Api page
3. Add the host with :9999
4. Load my IanTestWeb.qxw file from google drive
5. Back in the Mac computer the file opens but says New Workspace as the name in top bar. (This may be problem?)
6. Click on button on iPhone "Red Scene" (should I see anything in program on Mac change accordingly? I don't see anything triggering.
7. I then click on green arrow to try in Operate Mode
8. Then click Button on iPhone and now crashes after putting QlC into Operate mode.
Hope that helps?
Again, all the same steps using Chrome on MacBook work as expected and trigger the scene
Thanks a ton!
ianjamespiano
Hello!
Using Android device with same steps things seem to work as expected. Maybe there is a bug with iOS?
Cheers!
plugz
Real Name: David
I tried with an android device too, and another computer, and I can't reproduce the crash.
Maybe an issue with iOS chrome. I won't be able to work on this issue, sorry.
ianjamespiano
Thanks for the replies appreciate it!
I'll just use Android to control remotely for now.
Thanks!!
I made a donation thanks for your time and help!
I have reproduced this on iOS. Using Safari.
Please hold on while I try to understand what's going on
I think I have fixed it.
Can you please try the TEST version here: viewtopic.php?f=12&t=3135
and let me know if the problem is solved ?
Can anyone please give the TEST version a try ?
