Fixture creator 4.10.3 and caps lock
michilson
Real Name: Michael Chilson
Hey Guys
Love the software keep up the great work. I'd love to help test bugs I'm using this on a multi-Universe system and a Large lighting rig.
My Issues:
Inside the Lighting Fixture Creator inside the Channels Tab, The name Field only has about a 10 Character Value ( Try to Type in MAIN DIMMER ) You get (MAIN DIMME)
Also within the Description on the Capabilities section Same issue (Description only allows (10 Characters).
Thanks Please let me know if there is anything I can do to help beta test things for you guys!
Mike
plugz
Real Name: David
No issue here on linux.
Which OS are you running QLC+ on ?
Did this happen on older versions of QLC+ ?
Thank you
michilson
Windows 7
Just upgraded to new 4.10.3
I am not aware of this issue on the older version however I do not have the old version to check.
michilson
The issue seems to be related to CAPS LOCK
IF you CAPS all the letters you can only use 10 characters if not seems to be fine
Is your caps lock key broken ?
Cause you write in caps also in this forum, which is something I personally hate and find useless.
Please just don't.
