I've noticed that the effects speed in xy pad is not real time affected by speeddial in VC.
You have to switch between effects to change the speed of the effect. I think this is not the way things should work. Is there a solution or workaround for this problem?
Platform Win10. Latest QLC version. Workspace attachted.
Regards,
Rudi
Issue with xy pad and speeddial
- Real Name: Rudi Donné
- speeddial-xypad.qxw
- (7.05 KiB) Downloaded 99 times
There is a problem indeed. For now, create normal buttons (possibly in solo frame) to start the effects. That way they will react to speed change.
Confirmed: XYPad do not react to speed change from speed dial. Also the preview does not react to speed change at all.
If the issue is confirmed, can we add an issue to gitHub so this doesn't get lost in the forum torrents ?plugz wrote:working on it...
