OSC Connection fails after a while (OSX & QLC 4.9.1)
chapeau_melon
Back to the original post subject... I'm new to QLC and OSC ... I, till now, handled most of the things I wanted using both excellent pieces of software (Thanks to the creators !) ... except I now have the same issue... QLC fails to react to OSC input after a while :(...
I read this post, and indeed, the switch between 127.0.0.1 works ... but in the heat of the action, I don't want to stress on this :( ...
What is the latest news on this ?
Thanks in advance,
Have a nice day !
chapeau_melon wrote:What is the latest news on this ? !
Thr latest news is that QLC+ 4.10.1 should work now. Have you tried it ?
chapeau_melon
I'm on the latest downloadable version 4.10.1 ... I (still) have the issue... :(
chapeau_melon wrote:I'm on the latest downloadable version 4.10.1 ... I (still) have the issue... :(
Then please explain again your setup and what you're doing. Thanks
chapeau_melon
Doing nothing special... I attached some screenshots of the setup.
Just playing around and then for now obvious reason, the TouchOCS (still gives output - blinking green led) is not read anymore by QLC...
It is 'what ought to be' random, I cannot think about a fixture or scene or whatever that causes the halt.
As suggested in this post, switching to and back from 127.0.0.1 reconnects the TouchOCS
more in second post...
chapeau_melon
chapeau_melon
I'm running on Windows 7 64 - SP1
TouchOSC is running on my Ipad V2
Enttec DMX USB Pro MK2
Could it still be an "overload" of data ? ... I play quit a bit with the TouchOSC ... with the sliders ... going from one fixture to another ... etc...
TouchOSC is configured as follows :
- no doubletap / no flip / no Ping / no Accelerometer / no TouchMessages
- MidiBridge disabled
- CoreMidi disabled
V 1.9.4
You must be kidding me.
This thread is called "OSC Connection fails after a while (OSX & QLC 4.9.1)" and you report an issue on Windows 7.
4.10.1 for Windows still has the OSC issue. You need to use a TEST version that I built later: viewtopic.php?f=12&t=3135
Next time, please provide the necessary information since the beginning. It saves time to everybody.
chapeau_melon
My deepest apologies :(
I continued on this post since I thought OSX was in relation to the OSC soft on the Ipad :oops:
Again sorry for the annoyance :( ... I'll read the post you pointed !
chapeau_melon
For what it's worth, if other 'dumb' people like me would stumble on this post ... with the latest beta version provide in this post, it works like a charm on Windows...
Thanks again for all the help !
