I just tested some adapters on OS X:
- The DMX4All StageProfi Mk2 still works.
- The DMX4All NanoDMX works, too. Thanks for that!
- But the Eurolite DMX512-Pro does not work. It is recognized, but I can't get any output.
- It doesn't work to use more than one adapter. If I connect two of them, both are recognized. But as soon as I try to set the checkbox for the second universe I get the error message "An error occurred during opening the device". (And no output, of course.)
(All tests are made on a Mac with Yosemite, tried both with the Apple's own FTDI driver enabled and disabled)
[HEADS UP] Help needed to test incoming version 4.10.0
The Eurolite should work in OSX only if the driver in use is "QtSerialPort". Is that your case ?Flo wrote:But the Eurolite DMX512-Pro does not work. It is recognized, but I can't get any output.
Unfortunately I don't have the device, so I mostly copied the sequence I used for the NanoDMX.
More details please. Which adapters did you try to use together and which driver were you using ? (libFTDI or QtSerialPort)Flo wrote:It doesn't work to use more than one adapter. If I connect two of them, both are recognized. But as soon as I try to set the checkbox for the second universe I get the error message "An error occurred during opening the device". (And no output, of course.)
The Arch repository seems to be online, so if it worked with qlcplus-qt4, it should work with -git version too. (the files are in the same place)debbio wrote:On archlinux x64 with ENTTEC Mk2, qlcplus-qt4 works without problem.. Adding your repository and trying the version qlcplus-qt4-git I receive a 404 error on the server, no problem with qlcplus-qt4
Can you please post the complete error message ? Maybe the URL causing 404 is just wrong.
- Real Name: Florian
Yes: "Driver in use: QtSerialPort"mcallegari wrote:The Eurolite should work in OSX only if the driver in use is "QtSerialPort". Is that your case ?Flo wrote:But the Eurolite DMX512-Pro does not work. It is recognized, but I can't get any output.
One thing to mention: QLC+ doesn't seem to automatically set the right protocol mode for the adapters. I have to manually switch it between "DMX4All" and "Eurolite" in the settings.
I tried the combinations StageProfi+NanoDMX and NanoDMX+Eurolite. All of them use the QtSerialPort driver. How do I activate the libFTDI driver?mcallegari wrote:More details please. Which adapters did you try to use together and which driver were you using ? (libFTDI or QtSerialPort)Flo wrote:It doesn't work to use more than one adapter. If I connect two of them, both are recognized. But as soon as I try to set the checkbox for the second universe I get the error message "An error occurred during opening the device". (And no output, of course.)
Are there plans to enable the two new adapters on Windows, too? And, BTW: The new feature to reset single channels in the simple desk is great! I missed that a lot.
I just found another little bug:
I manually set the channels per page of the simple desk to 30 (because 32 are too wide for my MacBook). Now I can't reach the last two channels (511 and 512) because after page 17 QLC+ directly jumps back to 1.
Fixed in git.Flo wrote:I just found another little bug:
Here it is the error code on archlinux:
:: Vuoi procedere con l'installazione? [S/n] s
:: Download dei pacchetti in corso...
errore: impossibile scaricare il pacchetto 'qlcplus-qt4-git-4.10.0.20150929.063005b-0-x86_64.pkg.tar.xz' da download.opensuse.org : The requested URL returned error: 404
attenzione: impossibile scaricare alcuni file
errore: impossibile eseguire l'operazione richiesta (errore inaspettato)
Si sono verificati degli errori, nessun pacchetto è stato aggiornato.
Got it. You're trying to download a version that's not on the server anymore.debbio wrote:Here it is the error code on archlinux:Code: Select all
See here: http://download.opensuse.org/repositori ... ra/x86_64/
Being GIT versions, I retrigger the build every few days, so you should update your packages list before trying to install a GIT version.
Now I have no idea how this is done on Arch. On Ubuntu it is something like "apt-get update"
In theory you should never touch the protocol mapping. Can you please delete your QLC+ preference file and start from scratch ?Flo wrote:One thing to mention: QLC+ doesn't seem to automatically set the right protocol mode for the adapters. I have to manually switch it between "DMX4All" and "Eurolite" in the settings.
You actually found a monster bug. It was there in 4.9.x too. It's fixed now on GIT.Flo wrote:I tried the combinations StageProfi+NanoDMX and NanoDMX+Eurolite. All of them use the QtSerialPort driver.
In OSX, just disable the Apple driver and all the adapters should be detected by libFTDI.Flo wrote:How do I activate the libFTDI driver?
No. Windows works with drivers and each adapter must have its own. With FTDI adapters it's easy cause there is a documented SDK to use them.Flo wrote:Are there plans to enable the two new adapters on Windows, too?
NanoDMX and Eurolite don't use FTDI chips, so I suppose they have their own drivers and I'm not planning to support them.
- Real Name: Chris Gill
I'm noticing that on Mac OS X 10.10.5 (14F27) using QLC+_4.10.0-TEST-20150925, the "Set Background Image" function isn't working for Buttons or Frames. This is a very important feature for my church. We have gradient images created that visually show what color scheme a button will recall.
Thanks,
Chris
Thanks,
Chris
- nedmech
- Real Name: Nathan Durnan
Ditto on Win7 and Linux Mint KDE 17.2 - although I only have a problem with the button background images - frame background images work OK for me on those two OS's.DrumAnimal05 wrote:I'm noticing that on Mac OS X 10.10.5 (14F27) using QLC+_4.10.0-TEST-20150925, the "Set Background Image" function isn't working for Buttons or Frames. This is a very important feature for my church. We have gradient images created that visually show what color scheme a button will recall.
- Real Name: Ovidijus
What do you mean "delete button"? Are you talkin about delete button in the QLC app (this one works for me on OS X), or about backspace in your keyboard?Tasaei wrote:Hi,
with OS X 10.10.5 i can't delete thing in the virtual console with the delete button.
Don't know if i'm the only one.
ENTTEC PRO Mk2
AKAI APCmini
ENTTEC PRO Mk2
AKAI APCmini
- Real Name: Jasper
backspace on my keyboardOvis wrote:What do you mean "delete button"? Are you talkin about delete button in the QLC app (this one works for me on OS X), or about backspace in your keyboard?Tasaei wrote:Hi,
- Real Name: Jasper
Another thing:
New project.
1 cameo flat par 6channel mode.
Function wizzard: 16 colours an the whole virtual console thing.
selecting colours in the virtual console Works great.
Now just put the red green an d blue to LTP. the colours don't work anymore.
New project.
OK, that worked. The protocol is now always set correctly. But the Eurolite still doesn't produce any output.mcallegari wrote:In theory you should never touch the protocol mapping. Can you please delete your QLC+ preference file and start from scratch ?
It's a pity, but I can understand you. Nevertheless if you somewhen should have too much time I would be very excited...mcallegari wrote:No. Windows works with drivers and each adapter must have its own. With FTDI adapters it's easy cause there is a documented SDK to use them.Flo wrote:Are there plans to enable the two new adapters on Windows, too?
- lorenzoandreani
- Real Name: Lorenzo Andreani
Fixture Editor: Problem with editing existing fixture.
- Open existing fixture
- Double click on channel (eg. Color Wheel)
- Edit first step 000 - 013 and edit in 000 - 001
- Insert new step 000 - 013
- Click Ok and exit, save and close
The second step is not saved
If i open the fixture the second step is not saved and QLC+ not be shown the error of lack of continuity of the steps
OSX: QLC+_4.10.0-TEST-20150925.dmg version
Last edited by lorenzoandreani on Tue Oct 06, 2015 12:24 am, edited 1 time in total.
- Real Name: Daniel
Hi there, I'm back with two bugs / usability problems I've found.
The first affects the RGB efx feature which turned out to be a very useful thing and I'm planning make use of it, but I think it would benefit much if there's a (tiny?) modification such that the actual "hue pahse" can be shifted like shown in the following picture: to allow a transition blue -> red -> yellow for instance.
I think the option to choose a radial color palette would also be very useful in many cases (to generate a infinite rainbow effect).
The next one affects the cue list side fader in steps mode.
I'm not sure if this is a bug or a not forseen (hopfully tiny) feature, but I would appreciate if the step can be selected by the fader before the playback button gets activated, currently it's only possible to manipulate the cue list after the list has been activated (or did I overlooked something).
I've also tested the latest git snapshot yesterday and I like the speed dial improvement that increase the usability and flexibility extremely in my case.
Greetings,
Daniel
Greetings,
Daniel
