Dear Forum, dear Massimo,
my respect for this wonderful development!
I tried to install your Image to a USB stick (sda0) as RPi 3 is able to boot directly from a stick.
This didn´t work, and I am wondering if its feasable to amend your configuration a little bit to make this working.
I am not very firm in editing or compiling, so keep in mind the solution should be a newbie way
thanks for checking on that or maybe another member already has a solution?
Very best regards from berlin
Marcus
RPI3 Massimo Image boot with USB-Stick
- Real Name: Marcus
RPi3, Faytech 10" Touchscreen, Enttech USB-DMX, Macbook Pro 13"
- Real Name: Marcus
Thanks for this reply.
I already know this way to make a rpi bootable from a usb stick.
If I store the complete installation package from massimo to a usb stick and if I change the device in the config file to sda reference the bootprocess stops with two lines and freezes.
Massimo: is there a reference to sdcard while your image is loading all necessary bootfiles?
Thanks for checking.
Best regards.
Marcus
Best regards.
Marcus
No, there is not.Massimo: is there a reference to sdcard while your image is loading all necessary bootfiles?
My image is basically a Jessie image with Qt and QLC+ package pre-installed.
You might try the vanilla Jessie image from the RPi site and see how it goes. If you can boot that and not mine, I'll have a look into it.
