Raspi Raspbian QLC+ Start at Boot question
tavonmarkov
Real Name: Tavon Markov
Post by tavonmarkov » Mon May 22, 2017 6:20 pm
Can somebody, anybody point me in the right direction to help me get QLC+ to start right at boot? I am using Raspbian 8 (Jessie) on a RasPi 2 Mod B.
I have attempted the rc.local edit with adding a "qlcstart.desktop" script that commands a "start.sh" script... and still nothing happens on boot.
My "qlcstart.desktop" runs correctly when I double click it, as it is executable, but if I try to run it within a terminal window, it replies that the command isn't found...
I apologize in advance, I am not a fluent Linux user.
Thanks for the help!
janosvitok
Real Name: Jano Svitok
Re: Raspi Raspbian QLC+ Start at Boot question
Post by janosvitok » Mon May 22, 2017 6:37 pm
try to start /usr/bin/qlcplus from your rc script.
You can find the exact location by "which qlcplus".
tavonmarkov
Post by tavonmarkov » Mon May 22, 2017 7:02 pm
My QLC+ program is located at
/home/pi/qlcplus
In my /home/pi directory, I have two files I created:
start.sh
qlcstart.desktop
start.sh contents:
sudo qlcplus &
qlcstart.desktop contents:
[Desktop Entry]
Name=qlcstart.desktop
Comment=Launch QLC+ Application at Startup
Exec=/home/pi/start.sh
Terminal=false
Type=Application
rc.local contents:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
printf "My IP address is %s\n" "$_IP"
fi
#Start QLC+
/home/pi/start.sh &
exit 0
When I try to run rc.local in terminal window. I get
pi@qlc-pi:~ $ /etc/rc.local
My IP address is 192.168.1.12
pi@qlc-pi:~ $
Q Light Controller Plus version 4.11.0 GIT
This program is licensed under the terms of the Apache 2.0 license.
Copyright (c) Heikki Junnila (hjunnila@users.sf.net)
Copyright (c) Massimo Callegari (massimocallegari@yahoo.it)
--- i then have to hit enter before QLC Starts. If I change the lines after '#Start QLC+' to:
/home/pi/qlcstart.desktop
--- then run rc.local in terminal window. I get
pi@qlc-pi:~ $ /home/pi/qlcstart.desktop: 1: /home/pi/qlcstart.desktop: [Desktop: not found
/home/pi/qlcstart.desktop: 3: /home/pi/qlcstart.desktop: QLC+: not found
^C
