Hello Everybody,
I'm trying to Programm a Chaser for GPIO Pins. I can controll the Pins with the "Simple Desk" so the DMX Values and the Mapping in the Plugin works well.
But when I create Scenes for the Pins and put them Into a Chaser the Values of the Pins dont Change (I have tested it with the integrated "Monitor" Tool and with some LED's on the Pins).
How can i solve my Problem?
Thanks.
Can you attach your qxw file?
How do you start the chaser?
- Real Name: Philipp
i have attached the .qxw File.
I start the Chaser with a Button on the Virtual Console.
- GPIO Chaser.qxw
- (3.24 KiB) Downloaded 55 times
It seems that if you enable fading in the channel properties dialog, then it works. I don't have explanation for this (yet).
