Hello alls,
Sry for my english ist hope you understand me
Question 1:
Is it possible to start a qlc Show per ssh command line/crontab?
Question 2: when its possible...
Running Show 1...
Start over running Show another Show 2 with different priority and Show 2 is end.... Shows Show 1?
By the way great Job massimo
Start a Show from command line?
Hi, I think you can solve this by using two projects with one show in each.
Then hook QLC+ to cron or whatever and load the project with the -o command line option.
Also, remember to set each Show to autostart in the Function manager (green flag)
- Real Name: Timo E
thx massimo for your reply ,
I cant send commands ... i get the "cannot connect to x server"
Info i compile the progamm on my raspberry pi b+ v 1.2 on a ola image .
On rdp the software runs and i can use it... at commandline "cannot connect to x server" ...
Whats the problem ?
Best regards
Timo
Whats the problem ?
Best regards
Timo
Well, I'm not sure I fully understand what is your setup, but I guess the OLA image (and my image as well) doesn't include an X server, so if you built QLC+ from sources, the default rendering method is XCB, which requires a running X server.
In my image the default rendering method is EGLFS, which is available with Qt5 though. Basically you could try to build with Qt5 and launch qlcplus with --platform eglfs
- Real Name: Timo E
Ok i understand i think it isnt possible with the rpi1 b+
I give up
I hope it is possible with the rpi3 it will arrive at thuesday.
Can you tell me if a OLA & QLC+ Image exists?
Or can you tell me which is the right way to make both packages install on Raspbian Jessie lite?
Best regards
Timo
I give up
Best regards
Timo
- Real Name: Timo E
In the evening i will donate 15€ to you and hope you Support me
I use following Hardware :
Raspberry PI 3
http://yourduino.com/sunshop//index.php ... tail&p=323
https://m.aliexpress.com/item/32693761209.html#autostay here the ws-dmx-6ch-ban-v3
The setup was running at my older rpi1 b+ v1.2
I use the native-uart Modul from OLA and it was running
Because qlc+ was very slow and command line says cannot connect to x Server.
Tomorrow i arrive a new rpi 3 and we will see... I hope so
Raspberry PI 3
