RGB Matrix not saving correctly
janson
I created a smiple Project with a small RGB Matrix (2x50 Pixels) and copied it on the Raspberry.
It turns out that even when I save the project on the raspi, QLC does not correctly save the RGB functions.
I have to set the Fixture Group of all RGB Functions to none and back to my RGB Matrix in order to get it working. The colors also do not seem to save correctly.
I use the latest Raspberry Image.
Please help, It is an productive environment :(
Please post step by step instructions to reproduce the behaviour and note what is wrong.
(I.e. 1. open fixture tab, create rgb panel 2x50 RGB mode
2. go to functions tab, create new rgb matrix, name: xxx fixture group: xxx,... )
3. ...)
It may help if you can attach qxw file here as well.
If you want fast response, you need to provide as detailed description as possible, so that the developers
don't have to guess what's the problem.
Does it happen on a normal computer (windows/linux/osx)?
janson
The project works well on OSX. When I use the same file on the raspberry, the issue occurs. I will attach the file here. My guess is that qlc on raspberry somehow forgets the orientation or parameters. (EDIT: file deleted)
Again, can you describe step-by-step how to reproduce the error? Was I not clear enough?
I might know what it is.
The latest version I released for RPi includes a GIT version of QLC+ 4.10.5, which had some changes to the RGB matrix preview.
Turned out later that I found some issues with script parameters, that are now fixed on GIT.
@janson: do you have access to a previous RPi image (20160529) ? If so, please use that for your case.
Otherwise, if you tell me your name or email address, I can provide the links to download it.
Soon I'll release QLC+ 4.10.5 for desktop and RPi as well.
janson
Tanks for your reply :) Yes, I have access to the old version. I will try it and report back.
janson
I tested the suggested version and it works! :D
@mcallegari: so keep the issue in mind when releasing the next version. :roll:
janson wrote:I tested the suggested version and it works! :D
As I said, it's already fixed (on Nov 5th)
