Removing the header from web interface
Hockeyman271
Real Name: Stephan J Pivirotto
Hello once again,
Is it possible to remove the header from the web interface? below ive attached a picture of what im talking about. Id like to be able to preset all of the settings that this header allows you to do them remove it once i am done.
I think you can tweak the common.css file and change the controlBar class.
Since you haven't told us which OS you're using, I can't tell where that file is located in your system
Hockeyman271
Im sorry I completely forgot to mention that I am running QLC from a raspberry pi 3 with the QLC_Jessie image, i donated on here to get.
Thank you for the response though!
Hockeyman271
It worked! At first I tried removing most of the code from the common.css file but that only caused the design elements to disappear, In the end just changing controlBar class to have a width and height of 0 pixels "removed" the entire top bar and buttons.
Thanks for the help Mcallegari!
