In new version with DHCP the OLA not ip adress working,
ip static on QLC setting
OLA no IP!
- Real Name: Mihai Andrei
What kind of issue report is this ???
You want to connect to a WIFI INTERFACE in DHCP, and you're using the ETHERNET STATIC IP to access the OLA webpage.
Is OLA even configured to run on the WiFi interface ?
Please clear up your thoughts before posting here.
I am accessing from LAN and I want ola on the LAN and the simplest thing
good. I put the dhcp on both LAN and on wifi and ola still does not have an IP address ....
thank you
thank you
Tried even on the Raspberry Pi 2 QLC + 4.10.5 GIT pro OLA still does not have an ip address!
What he does not like ??
Ola I stopped and restarted, and as if by magic the ip address now ...
[/code] if we restart the raspberry touches restart ola wits remade as before ... in the command line I get this message and I will not be the recofigure ola window ..:
pi@raspberrypi:~ $ sudo dpkg-reconfigure ola
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "it_CH"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "it_CH"
