Waveshare 10.1inch HDMI Touchscreen
sjames
Real Name: Sean James
Hi All,
I'm working on building a QLC+ based lighting desk for my own use, and picked up one of these screens to work with:
http://www.waveshare.com/wiki/10.1inch_ ... with_case)
I got mine on http://Aliexpress.com for about US$88. It's 1024x600, capacitive touch over USB, quite good viewing angle, and a decent size to work with. (I run QLC+ on an old Dell Mini 9 netbook at the moment, so this is actually a slightly larger screen...)
Anyway, I spent some considerable time trying to get it to act like a touchscreen, before finding this post from Massimo:
viewtopic.php?f=17&t=8814
This screen reports as a mouse on /dev/input/event0, like the Adafruit 5", so I edited the QLCPLUS_OPTS line in /etc/init.d/qlcplus , removing "--overscan" and adding "-plugin evdevmouse:abs" then added after the QLCPLUS_OPTS line:
export QT_QPA_EGLFS_HIDECURSOR=1
export QT_QPA_EGLFS_DISABLE_INPUT=1
result: perfectly working screen! However, I want to use a keyboard as well, so added "-plugin evdevkeyboard" to the QLCPLUS_OPTS line.
Back to the project for me - now that the screen is working, I need to finish building my custom fader wing...
Sean James <dancer/tech/teacher/artist/maker>
