I am new to using QLC+, I was handed an existing rig at a new club. The owner would like me to update it and start using software instead of hardware. So I was hoping some you advanced users on the forum could help me with .QXF definition files for the following fixtures.
American DJ Galaxian Gem 1R
American DJ Vizi Roller Beam 2R
American DJ Inno Pocket Twins
American DJ Event Bar Pro
American DJ Fog Furry 3000
American DJ Dotz TPar System (Found)
Thank You In Advance
Definition Request
- titigab
- Real Name: Etienne
Here are the first three manuals.
(vizi roller cut cause to high for upload)
- vizi_roller_beam_2r_DMX_Only.pdf
- (353.86 KiB) Downloaded 68 times
- inno_pocket_spot_twins.pdf
- (1.85 MiB) Downloaded 77 times
- galaxian-gem-ir.pdf
- (1.75 MiB) Downloaded 72 times
- titigab
Here are the three last.
I can try to make the fixture ASAP but it will take me a few days as I'm not familiar with the fixture editor at this time. (Nice exercise I think)
Cheers =)
Cheers =)
- dotz_tpar_system_photometrics.pdf
- (147.56 KiB) Downloaded 81 times
- fog_fury_3000.pdf
- (1.17 MiB) Downloaded 65 times
- event_bar_pro.pdf
- (1.26 MiB) Downloaded 59 times
- titigab
Now the Inno Pocket Spot Twins.
- American-DJ-Inno-Pocket-Spot-Twins.qxf
- (12.32 KiB) Downloaded 76 times
- Real Name: Lukas
Hey, thanks for sharing. I reviewed the definitions and corrected the following things:
- Galaxian Gem IR: Adjusted some capitalizations and typos.
- Vizi Roller Beam R2: Adjusted some capitalizations, added capabilities for every channel and pan/tilt degrees
- Inno Pocket Spot: Adjusted some capitalizations, added capabilities for every channel
- (12.87 KiB) Downloaded 62 times
- American-DJ-Vizi-Roller-Beam-2R.qxf
- (11.54 KiB) Downloaded 91 times
- American-DJ-Galaxian-Gem-IR.qxf
- (2.66 KiB) Downloaded 66 times
- Real Name: Lukas
- Event bar pro: Adjusted some capitalizations, added capabilities for every channel and pan/tilt degrees
- Fog fury 3000: Added physical dimensions
- American-DJ-Fog-Fury-3000.qxf
- (1.19 KiB) Downloaded 60 times
- American-DJ-Event-Bar-Pro.qxf
- (11.9 KiB) Downloaded 59 times
