Cameo CLMPARCOB1 MULTI PAR COB 1
errol6942
Real Name: Alan Willis
I'm hoping that someone might be able to help me out with a fixture definition for a Cameo CLMPARCOB1 MULTI PAR COB 1.
The link to the manual is http://adamhall.invaliddomain.de/out/me ... _PL_IT.pdf
Thanks for any help.
Freasy
Real Name: Jan F
please try this one and let me know, if everything works as expected.
errol6942
Thanks for that. Will run it as soon as I can...might be able to do so this Sunday.
errol6942
Hi Freasy,
ran this last night. Had a bit of trouble at the start in 17-channel mode 'cos some of the reds, greens and blue were out - when I faded in red I got blue, etc. So I edited the definition and got it working fine.
I'll post the edited file tonight when I get back from work.
Again, thanks for your help.
- Errol
Freasy
Real Name: Jan F
I'm sorry you had trouble. I looked it back and indeed, I accidently switched rgb 2 and rgb 3.
I hope it wasn't too bad.
This should fix even 12-channel-mode in which I had a swap too... Sorry again.
Cameo-CLM-PAR-COB-1.qxf
(15.68 KiB) Downloaded 72 times
Thanks for sharing! I've adjusted some smaller things.
(15.65 KiB) Downloaded 69 times
