Venetian VT-07 (Laser)
Facundo Piñeiro
can anyone help me with the fixture?
i couldnt find the manual :(
https://quicksearch4products.com/ar/ite ... C752260207
thanks
Boxy
It's probably a copy of another make so I suggest loading different existing fixtures to try and get some output in DMX mode.
Failing that could you play with the simple console and let us reverse engineer the fixture?
Facundo Piñeiro
First I want to apologize for my poor English, :(
now the news :)
i load a generic fixture with 7 dmx channel (in the link posted before tells that) in Qlcplus.
i found these info:
Chanel 1: 0-69 nothing, 70-209 auto, 210-255 manual
Chanel 2: Form/shape (Gobo)
Chanel 3: Speed ? (im not sure but the laser seems to move faster o slower when drawind the shape)
Chanel 4: Amount of dots when drawing
Chanel 5: Position Horizontal
Chanel 6: Position Vertical
Chanel 7: Size ?
I write all shapes/gobos of channel 2 , each shape occupies 2 values
example:
0/1 Dot
2/3 horizontal line
4/5 vertical line
5/6 twisted rombo
7/8 square
etc etc etc etc etc
do you need to write all shapes? ?
thanks
sf99er
this project is awesome!!! madprops to all involved!
i have a similar issue w/a dual "laser display system h206" (no other identifying info on device). i'm not finding any other lasers in the list of devices under "add fixture". i'll try the generic route as stated above.
if you get it working *please" share, if you will. thank you
