Good afternoon,
I am a newbie with QLC+ , and DMX in general, but I am trying to configure two new fixtures with the fixtures editor. After trying a lot of differents configurations, I do not manage to make my two new fixtures working in the Monitor.
The first one is a Briteq PAR56 100 WW, with 2 modes (1ch-mode & 2ch-mode). I am trying to configure the 2ch-mode. I cannot configure the strobe function of the 2nd channel, in order to make it works in the Monitor. When I increase the dmx value of the 1st channel (dimmer), the fixture is blinking at a constant rate in the Monitor, even if the 2nd channel (strobe) is off.
For the COB SLIM RGB, it's exactly the same. I cannot configure the strobe effect on the 2nd channel and I am not sure of the "multiple functions" on a unique channel.
Is there someone who can check my fixture profiles and correct the mistakes in my channels ?
Here you can find the manuals of the two fixtures :
COB SLIM RGB : https://briteq-lighting.com/fr/cob-slim100-rgb
COB PAR56 100WW : https://briteq-lighting.com/cob-par56-100ww-black
Thank you very much !
Briteq COB slim RGB + Briteq COB PAR56 100WW
- Real Name: Thierry
- Briteq-COB-slim-100-RGB.qxf
- (4.4 KiB) Downloaded 72 times
- Briteq-COB-PAR56-100WW.qxf
- (1.58 KiB) Downloaded 67 times
- Fxedel
- Real Name: Felix Edelmann
It's only the naming of the capabilities. Renaming them from:
to
worked for me.
<Capability Min="0" Max="5">Open - No strobe</Capability>
<Capability Min="6" Max="255">Increasing strobe speed (006 = slow 255 = fast)</Capability>
<Capability Min="0" Max="5">Open</Capability>
<Capability Min="6" Max="255">Strobe slow-fast</Capability>
Have a look at the Open Fixture Library! It's a project to collect fixture definitions in a unified format and make them downloadable for different lighting programs, including QLC+.
Thank you for you fast reply It is working except the rate at which the lights are blinking in the monitor.
Whether I set the channel on 35 or on 255, the blinking remains the same. Is it also the labelling of the capability ?
Is there a paper which contains the "good" labelling of capabilities to avoid this kind of problem in the future ?
Thank you
Thank you
- Fxedel
I don't know if and how it is possible to affect the strobe speed with capabilities. I tested these test capabilities:
All capabilities containing the word "strobe" are blinking at a constant rate, "1-20Hz" has no effect on anything.
Maybe you'll ask your question in Usage questions where chances may be higher to get a developer's answer.
<Capability Min="6" Max="40">Strobe 1-20Hz</Capability>
<Capability Min="41" Max="80">1-20Hz</Capability>
<Capability Min="81" Max="120">Strobe 1-20</Capability>
<Capability Min="121" Max="160">1-20</Capability>
<Capability Min="161" Max="255">Increasing strobe</Capability>
As I saw on the qlcplus extra from mcallegari GitHub, for another fixture, I also try the code below but it seems that the blinking rate remains constant too.
For the moment, it seems that, except this blinking rate, I can use my two fixtures with QLC+. It's a good start
Thank you for your time and your help I will follow your advice concerning usage questions.
<Capability Min="6" Max="255">Strobe 0 < Max</Capability>
- Real Name: Lukas
Showing the correct strobe in the 2D monitor is currently not possible with QLC+.
Anyway, it would be very kind if you could share your working fixture definition so it can be added to QLC+!
Regards,
Regards,
Hi siegmund,
I just added the two fixtures !
