3ch dmx rgb controller - ebay - led strip
DJPoppyD
Real Name: Dave Fragar
has anybody written a file for these things
need for a Christmas decoration
thanks
Tried Generic RGB fixture?
That should work
DJPoppyD
yes will try that just waiting on a power regulator to arrive :p
doughadfield
Real Name: Doug Hadfield
I've got one of these and yes, it behaves simply as a generic 3-channel dimmer. if you plan to connect red, green and blue LEDs to the three channels (respectively), then you could create a simple RGB fixture definition for it, so it would be recognised as a colour changer device in QLC+.
In fact, how about I knock up a simple 3-channel RGB colour changer definition for you right now....
Doug
Here you go - I've invented numbers for the physical dimensions and power output etc, as this will depend on what lights you attach to it. But this definition will allow you to use the RGB functions within QLC+. The definition defines only a single "head", so will think it's dealing with a single light.
Enjoy
EBay-3-Channel-Dimmer-As-RGB.qxf
(1.24 KiB) Downloaded 135 times
doughadfield
Oops, I've just realised that QLCPLUS already includes a generic RGB colour changer fixture definition, so i've just re-invented the wheel!! :-))
Never mind, it was fun...
Doug
mlohrey
Real Name: Mark Lohrey
You might want to read this as well. viewtopic.php?f=32&t=11071
