LightmaXX LED RGB Color Bar Stripe
CoS2000
Hello there,
i search for a fixture. The Device Name is:
lightmaXX LED RGB Color Bar Stripe 252x10mm LED´s DMX Wall Washer
I dont know if its the real name - here you can find it:
https://www.musicstore.de/de_DE/EUR/lig ... 004084-000
I hope somebody can help me. Is the last fixture i need...
Thank you for your help!
Freasy
Real Name: Jan F
Hello again,
here it is.
I don't get where there are different channel modes, since the only way you can "change" the amount of used channels is on channel 1. So there is just one mode...
Validated without errors.
lightmaXX-LED-Color-Bar-Spot.qxf
(4.01 KiB) Downloaded 161 times
CoS2000
Thanks aggain Freasy - You are my Lifesaver ;-)
But i think there are 2 Modes. In know one Mode turns the whole Bar Color and one Mod use 3 Segements for Color...
Hmm will Check it - i have a manual ;-)
Thank you very much Freasy ;-)
Freasy
Real Name: Jan F
CoS2000 wrote: Thu Aug 31, 2017 9:25 pm Thanks aggain Freasy - You are my Lifesaver ;-)
If you even find the section where you can switch the mode on the fixture itself, you might send it to lightmaXX. They don't have it in their manual apparently :)
It would be nice to report if you were able to sort out the issue regarding modes before eventually including the fixture in QLC+.
Freasy
Real Name: Jan F
siegmund wrote: Mon Sep 04, 2017 8:36 am It would be nice to report if you were able to sort out the issue regarding modes before eventually including the fixture in QLC+.
Well in fact according to the manual there is no way to switch the fixture itself into another mode. Just settings specific values on channel 1 set if other channels are used.
