While i will try to write my own fixture file would be great for an expert to also have a go please to see if i get it close to right. thanks all in advance
http://www.ebay.com.au/itm/352024817615 ... EBIDX%3AIT
Cheap ebay pin spot fixture request please
- Real Name: Dave Fragar
- ebay pin spot.pdf
- (745.4 KiB) Downloaded 71 times
this is what
i tried to do but it only take up one channel not six
what did i do wrong
thanks again
what did i do wrong
thanks again
- Ebay-Pin-spot-pin-spot.qxf
- (2.84 KiB) Downloaded 117 times
- Real Name: Mark Lohrey
Looks OK to me.
I added it to a workspace and it shows correctly with an address range of 1 - 6
You can also check your fixtures here: http://www.qlcplus.org/fixture_validator.php
You just need to add the mass and dimensions to the physical characteristics as a final tweak.
thanks for input refined version here
- (2.83 KiB) Downloaded 195 times
took the file to PC that runs the lights and it reported it as a 6 channel fixture
set up a simple test show with one light on DMX ch1-6 and it all worked as it should
thanks for all the help - very happy - another step in my QLC+ adventure
